Unknown unplugged wire
Old Mar 28, 2019 | 03:37 PM
Rwright97's Avatar
Swapped in a new year model 305, i have this last unplugged wire and i know it hooks up to this little module behind it, but the new wiring harness has a diffrent connector, what is this module?
Old Mar 28, 2019 | 04:05 PM
GeneralDisorder's Avatar
Re: Unknown unplugged wire
That goes to the ignition coil.
GD
Old Mar 28, 2019 | 04:56 PM
Rwright97's Avatar
GD
Will i need this ignition coil if this car is going to be carbed with an hei distributor?
Old Mar 28, 2019 | 09:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It looks like it’s coming from connector c100 next to the master cylinder. If it’s a pink wire it’s power to the coil/distributor. White wire is tach.
Old Mar 28, 2019 | 11:14 PM
You will need the wires going to that connector. For coil power (+), and tach signal (-).
But keeping the fuel injection would be better. Swapping a carb is just..... defeatist.
GD
Beast_Mode
Apr 29, 2010 08:15 PM
watafo
Oct 5, 2004 05:59 AM
doc
Sep 16, 2000 09:52 AM
