Knock sensor thread pitch
Old Apr 3, 2019 | 08:02 PM
Tonyy_z's Avatar
Hello guys so I have an 86 Camaro iroc . Engine was swapped with an l05 350 but previous owner kept tpi was going through engine and realized I have no knock sensor. I went to the store and bought one info on it says it has 1/4 in thread but doesnt seam to fit on either side of heads. The heads have a 3/8 threaded hole in it. Any advice on how I can get this to work. ?
Old Apr 3, 2019 | 08:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Knock sensor thread pitch
It goes on the passengers side of the block coolant drain. Not in the head.
Old Apr 3, 2019 | 08:11 PM
Drew's Avatar
I concur.
Old Apr 3, 2019 | 08:12 PM
Vader's Avatar
IIRC, it's a 1/8-27 taper pipe thread.
Old Apr 3, 2019 | 08:14 PM
Tonyy_z's Avatar
Thanks feel like an idiot it's there just not connected
Old Apr 3, 2019 | 08:21 PM
Engine: Lb9
Transmission: M20
The connector often gets brittle from heat from the exhaust.
if you need a new connector here’s a link.
https://www.ebay.com/itm/Knock-Senso...gAAOSwMapbaWOC
or as a pigtail
https://www.ebay.com/itm/Knock-Senso...ss!20876!US!-1
Old Apr 4, 2019 | 07:35 AM
Actually, pretty sure it's ¼" pipe. 18 TPI if memory serves. It's about a ½" dia hole, starts out life with a 7/16" drill. In the block on both sides, about 1" above the oil pan rail. KS goes in the pass side drain; driver's side just gets a plug. I strongly recommend brass.
tpiselli
Sep 14, 2008 08:46 AM
Zap Racing
Jun 11, 2005 07:24 AM
Andy89RS
Mar 10, 2002 10:12 AM
