Electrical issues
Old Apr 17, 2019 | 12:04 PM
bholmes's Avatar
Electrical issues
87 iroc 305/carb
Volt and temp gauges arent working. Fuse is good and getting power to cluster,as I have taken the actual gauge out of cluster, and checked with a test light. No power to alternator plug. Anything help/advice would be greatly appreciated
Old Apr 17, 2019 | 12:15 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Electrical issues
For the temp sensor. You can ground the green wire at the sender. The sender is in the drivers side head between cylinder 1 & 3. If the gauge pegs the wiring is good and you have a bad sender.
Old Apr 17, 2019 | 12:17 PM
Engine: Lb9
Transmission: M20
http://www.austinthirdgen.org/mkport...uges_part2.gif
Old Apr 17, 2019 | 10:29 PM
bholmes's Avatar
What would be the Energizer wire out of the plug, the tan wire or tan/white wire!?
Old Apr 18, 2019 | 05:55 PM
Engine: Lb9
Transmission: M20
not sure I follow .
Kitten Tooth
Dec 31, 2016 04:27 PM
Outlaw28
Mar 15, 2007 11:50 AM
Chris88Camaro
Aug 27, 2003 02:44 PM
CarAteMyMoney
Jun 22, 2003 10:31 PM
