Is it necessary to ground the gas tank?
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,
I'm restoring my gas tank with new fuel pump, filters, etc. I painted it with anti rust protector and I'm putting 2 new isolated "gaskets" on top of the tank and 2 on the straps where the tank contacts with chassis ans straps. In this way, the gas tank will be completely isolated of the car's chassis.
What do you think about the static electricity discharge or possible spark at the refueling process in the Gas Station when the methalic nozzle contacts the filler neck?
Thanks in advance,
Denis V.
Thanks in advance,
Denis V.
Re: Is it necessary to ground the gas tank?
No need. The sending unit is physically connected to a ground wire that grounds to the body in the interior when it's plugged into the bulkhead connector. It's already grounded.
Axle/Gears: No idea
Yes, you are O.K.
The tank body and the sending unit black wire (ground) are in contact.
Thanks again.
Thanks again.
Brynpowers
Jul 8, 2012 02:52 PM
nhra-trans-am
Jul 13, 2011 10:16 AM
un4givin89
Oct 6, 2001 04:20 PM
