Anyone any idea why I have so much gasoline fume in car??
Old May 19, 2019 | 03:56 AM
Camallen's Avatar
Actually getting serious now. After a drive I have a headache, bad taste in mouth. Car runs fine albeit very bad on feul economy. Awful stench of gasoline inside car, like way too much. . Thanks in advance.
Old May 19, 2019 | 04:22 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Re: Anyone any idea why I have so much gasoline fume in car??
Either the hatch isnt closed, exhaust leak, or the vent lines are not doing their job.
Old May 19, 2019 | 08:04 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
You could have a cracked filler neck. You get some pretty serious fumes especially if you fill the tank. From what I have read on here that this is a common problem. I would check the whole EVAP system.
Old May 22, 2019 | 08:37 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Someone probably cut a hatch up top to change the fuel pump, and didnt seal it, lol
Old May 23, 2019 | 08:29 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Is it only while you are driving? If you get in the car after it has been parked like overnight, does it have the strong smell?
Old May 23, 2019 | 08:49 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Years ago I had a 2.8 Camaro. It had an small exhaust leak. But the hatch motor was broken. The smell used to get in the car that way. Just check the fuel lines. I would smell the oil and check plugs to see if it's running rich.
Old May 23, 2019 | 08:54 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Leaking Fuel Pressure Regulator, can be your problem.
jaweiss
Jan 25, 2012 10:14 PM
TNT_Z28
May 25, 2010 06:13 PM
See You
Alternative Port EFI Intakes
Nov 8, 2008 07:08 PM
hpjspdr4l
Dec 11, 2003 12:32 AM
RMK
Dec 13, 2000 11:01 PM
