Oil Pan Question
Old Jan 9, 2002 | 09:29 PM
fattie92's Avatar
Oil Pan Question
on a motor swap,, do i need to worry bout the oil pan hitting the axel?? engine is a 355 from a 1972 corvette, its going in a 84 TA. will i run into clearance issues?
Old Jan 9, 2002 | 10:25 PM
wuter's Avatar
u may run into a problem with the y pipe hitting the pan, try to find out before installing its a bitch to have to pull it again.
Old Jan 9, 2002 | 10:36 PM
fattie92's Avatar
will the one on the 305 work on that??,,,how can i check to see if it will be fine, good old tape measure anda pencile?
Old Jan 9, 2002 | 11:29 PM
ronterry's Avatar
Car: '94 Corvette
You might have a problem if you don't have enough reach with the puller going in from the front.
That was the only problem I had, when installing a 350 w/7 quart kickout pan, and tranny on the engine.
I know now to leave a little more chain from hook to the puller.
Just lower down in there, and start going around taking a looksee. Just analyze from there.
You see that I don't have enough chain at the top. This install was a turd !!! But It cleared the crossmember, after some patience.
Ron
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
