Water Pump Leaking - Recommendations?
Car: 1985 IROC-Z
Engine: 383
Hello all,
When I built my car 6 years ago, I used a Weiand water pump (WND-9240P) purchased from Summit Racing. I just found a small puddle of antifreeze under the car, based on what I can currently see (I'll get it up on the lift tomorrow), I'm guessing that it's the water pump leaking. I just checked at Summit again, the pump gets pretty bad reviews for quality. I'm going to replace it, but don't want to use the same (crappy) one.
Can someone recommend a good replacement, preferably polished aluminum so it matches everything else? Thanks.
Re: Water Pump Leaking - Recommendations?
Apone
Oct 22, 2001 08:48 PM
