Smog pump replacement
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yo guys. How hard is it to change the smog pump on an 88 LB9? I think that is the source of the noise I’m hearing. Thanks.
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Smog pump replacement
Hardest part is getting the pulley off to get to the bolts that hold the pump to the bracket. After that mine came off in like 2 minutes.
Jester
Oct 1, 2000 08:29 PM
