car burning batteries
Old Jun 23, 2019 | 05:54 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
my car has burned 3 batteries in the last few months. when this happens when im trying to start it. the motor will turn over but sort of drag. when I turn the key to the off position it continues to crank. I have to unhook the battery to get it to stop. the battery was hot to the touch. I noticed there are no grounding straps. it sounds like it could be a grounding issue to me. once this happens the battery is no good. I can hook it up and it will give me enough power to use the power locks but wont try at all to engage the starter or turn over the motor. does anyone know if this is a ground issue or have other ideas? the car runs great once it starts. its just every now and then when im starting it that this happens.
Old Jun 23, 2019 | 10:20 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: car burning batteries
I would change out the starter motor and see if problem goes away-must be something wrong with the starter if it pulls enough current to ruin the battery.
Old Jun 24, 2019 | 06:43 PM
Evilokc's Avatar
Engine: tbi 305
I think your right. the starter has gone the way of the payphone. I will replace it.
Old Jun 25, 2019 | 11:23 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
If the alternator is over-charging the battery, that would be a problem and cause the battery to overheat, and the fix is a replacement alternator.
If the solenoid is sticking and the engine continues to crank even after you have let go the switch, either you have a bad ignition switch or the starter is bad.
I'd start with a new starter (no pun intended).
slowpoke89
Nov 8, 2005 05:42 PM
fireturd350
Car Audio
Aug 25, 2004 07:04 AM
Tyler-88
Car Audio
Dec 28, 2001 12:01 AM
MotorCityMuscle
Nov 21, 2001 02:08 PM
MotorCityMuscle
Nov 21, 2001 01:11 PM
