Valve train misalignment. What is the cause of this?
Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
Helping a guy out with resetting his lifters (solid flat tappet cam) and I noticed how misaligned the rockers were. What would cause this? My first assumption is that the pushrod guides are off and need to be cut or replaced with adjustable ones. Or maybe bad machining on the heads themselves? Thoughts?
Dart Pro1s. Dont know the brand rockers, knockoffs Im betting. 1.6s on exhaust, 1.5s on intake IIRC
Re: Valve train misalignment. What is the cause of this?
Fairly typical. Those look fine to me.
The factory design doesn't put the rockers dead-on straight in the first place; they're intended to be slightly off-center to make the valves rotate. Aftermarket heads, where they've widened the intake ports and done other things such as that, are often even more exaggerated than stock. Note that the one that "looks" more off, is the intake, which is the valve and port that are usually more heavily massaged in the aftermarket.
Doesn't particularly matter in most cases. If it's REALLY bad, like if the rocker rollers are about to fall off of the valve stems, you can cut the guide plates in half and re-weld em to straighten it out some. But you don't want to take out ALL of the "misalignment" regardless.
I did that on some BBC heads before installing shaft rockers.
I agree that those look normal. It's nice to have them centered but not a requirement. It's more important to get as small a sweep as possible across the valve tip through the cam lobe rotation. This also isn't required to be directly on the center of the valve tip.
Yeah - I had to do some searching when I encountered this situation building my Vortec. I did get adjustable guide plates and made things as close as possible but with full rollers the trunnion bearing has some side-to-side slop and is going to flop around back forth across the tip of the valve stem. I tried to split the difference but the adjustable guide plates are a motherlover to keep in one position while tightening the rocker studs.
In the end one just has to embrace the fact that these are 1950's technology. Not a swiss watch.
Yeah on some heads adjustable plates are needed to align things. But can be abit of a pain to keep aligned. Some guys tack weld them together. I didnt and it was fine
