Bar Debate: Stealth Ram on Cam, and YPipe on stock heads and exhaust mans -worth it?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I'm starting to burn a little cash on my high miler (120,000 miles) LB9. I'm putting a T5 in (from the TH700R). As well as a GM 94666942 cam, and MAC Y-pipe. I'm teasing the idea of a stealth ram (Weind 7540) flowing through the stock heads and stock CAT, stock TB. In my defense I do have the Bosch D3 injectors and am signed up for a tune with Scott Hansen. I can always move that stealth ram to a cool rat motor build later. What do the forum members think? Waste of money right now at $450 for the ram intake?
Re: Bar Debate: Stealth Ram on Cam, and YPipe on stock heads and exhaust mans -worth
You would also need the matching fuel rails. It's more like $700. The TPI rails don't fit. Then later the throttle body won't be big enough so there's another expense.
IMO, the First Performance intake is a better deal at $1000. Comes with everything.
GD
GD
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Its all relative lol there may be some gains and a definite shift in power curve, so that may be worth it to some. Others maybe not. If you plan on a bigger build down the road keep the hsr
AFAIK it is not legal in CA.
Engine: 350 TPI L98
Transmission: WC T5
Yeah, I'll hold onto my $$.. for now. Maybe a 100 shot instead.
Fronzizzle
Alternative Port EFI Intakes
17
Jan 9, 2012 09:01 PM
The White Knight
Jun 4, 2008 04:28 PM
Jim85IROC
Mar 30, 2002 04:44 AM
