Rehashing the Stealth ram debate, specifically for my application
Old Mar 26, 2002 | 09:09 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ok, I just got the shaft on the SLP runners I was going to buy, and I didn't get the accel base yet, so I'm considering going with the stealth ram, although I'll probably wind up waiting all summer for it.
But... I'm running 461 heads, with a hydraulic cam (314/224 .442/.465 112lsa), TRW flat-top slugs, 24lb injectors, headers, blah blah blah.
Obviously my heads aren't all that good, and the hydraulic cam isn't doing me any favors either.
I could do a cam swap, but converting to a roller is beyond my budget. Heads would be down the road.
So anyway... let's say I go with the stealth ram. Am I going to be giving up anything compared to the accel base & slp runner combo? I suspect a fair amount of low end torque will be lost, but I'm trying to figure out if I'll have enough midrange and high end to make up for it. This would be an easier bench-race if the stealth ram had a proven record.
Anyway... what are your thoughts?
Old Mar 27, 2002 | 08:53 AM
Beefy89's Avatar
You won't be giving up as much money with the Stealth Ram.
Old Mar 27, 2002 | 09:02 AM
Jim85IROC's Avatar
Thank you, Captain Obvious!
Old Mar 27, 2002 | 09:17 AM
Beefy89's Avatar
Well I guess the only way to know is to A: Wait for some real numbers to come out for the Steath Ram,or B: Buy one and find out yourself.
But I (like yourself) would guess that one would lose a little low end with the Holley.
Old Mar 27, 2002 | 09:20 AM
Jim85IROC's Avatar
Right now I'm leaning toward the "Buy one and find out yourself" option. I dunno. If I was smart I'd just buy the accel base, put the damned base and runners on the car, and buy the stealth ram later on. I could always throw the base & runners onto my other car.
Old Mar 27, 2002 | 02:09 PM
Guido's Avatar
Car: 2000 Trans Am
Skip the TPI base.
Stealth Ram.
Ring someone's bells and get you one NOW.
If you really want one, you can annoy someone enough to GET one.
Old Mar 27, 2002 | 02:38 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Question is will the stealth ram fit under the factory hood? Looks kind of tall from the pics on Holleys' site.
Old Mar 27, 2002 | 03:30 PM
Iroc n roll's Avatar
TPI is no slouch either. Damn thing is huge. And there is still room under the hood. I think the Stealth ram will fit fine under a camaro hood at least since thats what I'm used to. If not its a good excuse to lighten up the front end and get a fiberglass hood.
Old Mar 27, 2002 | 03:38 PM
Jim85IROC's Avatar
the stock TPI has a height of around 9.3". The stealth ram is around 10" high. The system itself should have plenty of clearance, but because the throttle body isn't angled down, there's a chance that it could hit. Considering that there's room for strut tower braces to fit between the stock TPI and the hoods, I'm guessing that fitment won't be an issue, but I can't know for sure.
If I do decide to go this route, I'll slap the stock hood back on and check.
Old Mar 27, 2002 | 07:45 PM
Fastcamaro87's Avatar
here
i think u should talk to the guy that posted the link above, from the look of it , he made his own stealth ram,
hope this helps
Old Mar 27, 2002 | 07:59 PM
Jim85IROC's Avatar
Originally posted by Fastcamaro87
here
hope this helps
Basically, that's exactly what he did. But... it cost him about as much as the Holley kit. I planned on making something just like it, then holley answered my prayers... and even made it affordable. Now I just gotta see if the rest of my motor can handle it.
Old Mar 27, 2002 | 08:05 PM
89transam's Avatar
Question on steatlth ram....we can use the same injectors correct? I mean all we need is the manifold and rails?
Im excited about this thing
Nate
Old Mar 27, 2002 | 09:18 PM
Jim85IROC's Avatar
I talked to a holley EFI guy, and this is what he had to say about the stealth ram on my motor:
"I don't think it will be a problem. Might not make the same torque at say 2000 compared to a TPI, but I think it will be fine. The lowest HP engine I dynoed it on was a mild 350 with a similar cam to yours that put out 400 HP and had very good bottom end torque still. With that cam and heads it should make good power to 5500 easy."
I asked him what kind of heads that 400hp motor had but he hasn't gotten back yet. I'm still up on the air over this vs. superram base and SLP runners.
Old Mar 28, 2002 | 11:49 AM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
The photos I saw looked like there weren't any provisions for EGR. Is the manifold smog legal? I have to go through biannual inspections.
Old Mar 28, 2002 | 11:59 AM
Jim85IROC's Avatar
I don't believe it has provisions for EGR, although I'm sure you could rig up an exterior EGR setup similar to how the Corvette is set up.
Old Mar 28, 2002 | 01:08 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You can always slap on the slp runners with the accel base. I have a superram, and trust me, you aren't missing much.
Try the stealthram, it should be interesting.
I'm going to try an LT1 intake soon myself.
Old Mar 28, 2002 | 01:25 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yeah, if i were you i'd just run the stealth ram. Like the holley rep said, it isn't going to lose that much bottom end, again i take everybody back to the carb manifold analogy.
Old Mar 28, 2002 | 02:23 PM
Jim85IROC's Avatar
Too late.
I've already made up my mind that I'm going with SLP runners and the accel base. If I get a 91 vette like I'm planning on, I'll move that crap to the Vette and put the stealth ram on the IROC.
Right now I want something simple until I get my other issues in order (transmission, posi, and most importantly, ECM & harness swap). Not that the stealth ram would be overly difficult, but it would require me to modify my fuel lines, get a new distributer and play water-neck games.
Old Mar 28, 2002 | 04:25 PM
Hey, no guts no glory But I hear you about all those modding headaches. Things never seem to fit the way you want them to. You'll save some cash with the SLP stuff even though the performance won't be like a stealth ram. But its a good idea to get issues resolved before creating more. Maybe the stealth ram will be cheaper when you go for it
Old Mar 28, 2002 | 04:43 PM
Ed Maher's Avatar
Car: 04 GTO
So siamese that base and port the runners up real nice, you won't be so bad off. The stealth ram prolly would have been sweeat though
Old Mar 28, 2002 | 07:16 PM
Jim85IROC's Avatar
I'm not real sure I want to take a dremmel to a $400 intake just yet. Other than port matching, I think it's going to go on as-is.
But now I'm back to leaning toward the stealth ram
I can't friggin decide.
Old Mar 28, 2002 | 07:34 PM
Stealth Ram, Stealth Ram, Stealth Ram, Stealth Ram. Go for the glory. Be one of the first Thirdgen stealth rammers.
Old Mar 28, 2002 | 09:13 PM
Jim85IROC's Avatar
Dude, I just want my car to run right, and yet another experiment doesn't seem like the smart approach to solving my problem.
I want that stealth ram so damned bad tho.
Old Mar 28, 2002 | 09:52 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
talked with tom at holley today. the intake is 1/4" taller than stock. it is level from front to rear. he said the stock fuel rails might actually work. if not then 9900-172 is the fuel rail kit. comes with fuel rails, regulator, AN fittings for fuel lines, and crossover tube. will need to fab line to connect to stock fuel lines.
Old Mar 28, 2002 | 09:58 PM
Jim85IROC's Avatar
The fuel rail part number is 534-185
I've been talking with "Doug F" who happens to be one of the Holley guys that's very closely involved with the stealth ram, and is quite active on various EFI message boards. So far he's been quite a big help.
The stock TPI is 9.375" from top to the block rail, the Stealth Ram is just about 10". Its height might not be much more, but by not angling the throttle body, it will require a LOT more room. There isn't room under a Corvette hood. I'm unsure about an f-body hood, but I'd suspect that it would have a greater chance of fitting under a Camaro hood than a firebird hood.
Old Mar 28, 2002 | 10:12 PM
mrr23's Avatar
Engine: 360 HSR
well isn't that just typical. two different people, two different answers. but still 1/2"+ isn't that big a deal. did he say anything about the fuel rails? the number i have works at the summit site. $199.69 may be a superceded part number. i gave tom the part number i had for the manifold and he had a different one. he didn't know they changed it.
Old Mar 29, 2002 | 06:51 AM
Jim85IROC's Avatar
My number came right off the holley site, and was verified by Doug, as well as by a person that already has this system. This part number also works on the Summit site.
Here's the Summit info for your part number:
HLY-9900-172 FUEL RAIL $199.39
Here's the info for mine:
HLY-534-185 ACCESSORY KIT FOR #7540 $173.69
Notice that mine specifies that it's for #7540, which is the manifold part number.
Here's the blurb from Holley's site:
Manifold available separately under P/N 7540 and 7540P.
Fuel rail kit available separately under P/N 534-185.
And a link for it:
http://www.holley.com/HiOctn/WhatsNew/WhatsNew.html
You need to scroll down over 1/2 way to get to the original Stealth Ram section, dated January 22, 2002.
Old Mar 29, 2002 | 08:16 AM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
wondering....
Has anyone seen a EFI system with two different sets of injectors like 24 lb and 36??
So that a person can press a button to activate the 36 lb system for racing or whatever??
thanks,
it is just a thought..
:hail: :hail: :hail:
Old Mar 29, 2002 | 09:09 AM
Jim85IROC's Avatar
Re: wondering....
thanks,
Here's another thought. Just ask the question in 1 post or the other!
Old Mar 29, 2002 | 09:54 AM
GoFast91Z28's Avatar
Does anyone know exactly what is included in p/n 534-185?
Providing I can get my vortec heads set up to work for this- I plan to be a guinea pig. We have needed something like this (ie. cheap that really works good) for 15yrs. I have owned my car for 8 yrs. and I just cannot beleive that something this good has actually come along. I don't know if Holley had us third-gen and fourth gen guys in mind when they built this, but thank *** they use GM compatible parts for their aftermarket EFI setups.:hail:
Old Mar 29, 2002 | 09:59 AM
Trux's Avatar
Transmission: t-56
what is p/n 534-185?
I have looked at the holley web site and I don see it =(
can you post a pic of it or something, thanks
:lala: :lala: :lala:
Old Mar 29, 2002 | 10:12 AM
Jim85IROC's Avatar
Re: what is p/n 534-185?
And a link for it:
And a link for it:
And a link for it:
And a link for it:
And a link for it:
Old Mar 29, 2002 | 10:15 AM
Trux's Avatar
Transmission: t-56
What do you think??
look a these "pimped" EFI systems: http://force-efi.com/price.htm
Thanks for posting the links, I looked on their site and say different part numbers for the stealth ram, thanks.
So what do you think about those EFI systems????
thanks
:hail: :hail: :hail: :hail:
Old Mar 29, 2002 | 06:16 PM
Jim85IROC's Avatar
Re: What do you think??
thanks
What do you mean that they're different part numbers? The part numbers I posted CAME from that site.
Old Mar 29, 2002 | 06:18 PM
Trux's Avatar
Transmission: t-56
Um.. ok
I looked here at the stealth ram at first. This is a link from holley web site, http://www.nosnitrous.com/HiOctn/Pro...FMS/SR/SR.html
Old Mar 29, 2002 | 11:29 PM
Jim85IROC's Avatar
Those part numbers are all for complete EFI kits that include the whole enchalada, including the throttle body, injectors, harness, ECM, etc. Those are big bucks ($2700+)
I'm talking about just the manifold & plenum, and the fuel rails. That's the minimum you need to have in order to reuse all of your old crap.
Old Mar 30, 2002 | 04:44 AM
Trux's Avatar
Transmission: t-56
oh, ok =)
I would ned one of those kits, I am runing a carb
It has some great power but my mpg is under 10.
thanks:hail: :hail: :hail:
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
MrPackstin
Oct 25, 2017 08:09 PM
Vintageracer
Sep 24, 2017 12:34 PM
Gordonr1973
Sep 29, 2015 11:59 AM
