82 bird v6 5 speed no ignition acc power
Old Jul 5, 2019 | 08:08 AM
knightrider89's Avatar
I was driving my 1982 firebird and it died. I have no ignition, no power windows, no radio,no gauges. The only thing that works is dome light, horn, hazzard lights, the headlight will not go up. I noticed the rpm gauge was acting crazy before it died. Its a 5 speed so I wonder if its the clutch neutral safety switch. Its the S/E model with the v6 2.8l carb. I also put a new battery in it but still nothing.
Old Jul 5, 2019 | 08:54 AM
Re: 82 bird v6 5 speed no ignition acc power
Not the clutch safety switch.
It's a fusible link. There's 2 or 3 of them, at the starter. One is bad.
Old Jul 5, 2019 | 10:15 AM
Ill check the links on the starter. I just got it out of the shop and it was running great but it just died and i had to get it towed. My power windows wont roll up so i got a tarp over it.
Old Jul 5, 2019 | 10:32 AM
Old Jul 5, 2019 | 06:17 PM
The mechanic shop.He fixed the problem with the acceleration where I had to keep pumping the gas pedal to go faster. It was driving great like it should. It was accelerating great but it just died all of a sudden when I was driving it. I checked all the fuses and they was good.
Old Jul 5, 2019 | 10:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yep, check the fuseable links. They are part of the wire in the harness, not in the fuse box. As stated there are two, and what is working and what is not is consistent with one of them being blown for some reason.
Old Jul 24, 2019 | 09:35 AM
It was the wire under the starter. It had burned up on the exhaust. Its running great now Thanks!
pantywaste33
May 12, 2010 08:30 PM
Kandied91z
Mar 19, 2007 11:41 PM
Paipe90GTA
Oct 17, 2004 04:58 PM
PyRo9862
Jan 2, 2004 10:46 PM
jm91rs
Apr 17, 2001 11:17 AM
