Cruising RPM seems too high...
Old Jul 7, 2019 | 08:52 PM
Carlos89's Avatar
Car: 1986 Trans Am
Engine: 5.0 LG4 4BBL
Transmission: T5 5-Speed
Strange one guys. Took my 89 Bird (Tbi 305) on the highway for the first time. I have 4.10s and a 700R4 with an unknown stall aftermarket TQ converter. Also stock diameter 245/50R16s.
At 60mph I'm at 2350rpm in OD.
Isn't this a bit high, even for 4.10s??? Does a high stall converter affect the RPM range?
Old Jul 7, 2019 | 10:16 PM
Drew's Avatar
Re: Cruising RPM seems too high...
No, that sounds about right for a .7 4th gear, with a 26" tire and 4.10 gears. Even 3.73s that get recommended frequently are pushing it with the 700R4. 4.10s you're pretty much trading highway cruising for drag strip performance.
Old Jul 8, 2019 | 02:45 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
4.11's are very steep, not a very friendly automatic ratio for daily drivers with any automatic transmission
Even with 3.5's I am complaining about highway RPM and wanting 3.23's
I remember the factory 305TBI had 2.73's behind it's 700R4 and would drop to 1400rpm at 46mph or something
Old Jul 8, 2019 | 02:46 PM
Carlos89's Avatar
Car: 1986 Trans Am
Thank you guys I appreciate the info.
BTW, is there anything I can do to test what the stall speed is on my torque converter?
Old Jul 8, 2019 | 02:50 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
What rpm does the car start to move ?
Old Jul 8, 2019 | 05:32 PM
Carlos89's Avatar
Car: 1986 Trans Am
I'm sorry you mean at idle? I just put in drive and it moves, idles at 750.
Old Jul 8, 2019 | 05:55 PM
Engine: Lb9
Transmission: M20
Sounds like you have a stock converter
Old Jul 8, 2019 | 06:22 PM
Carlos89's Avatar
Car: 1986 Trans Am
Ok thanks. I was asking because the converter is blue and the PO replaced many components (rear gears, diff cover, intake manifold, headers and full exhaust, shift kit) so I thought he might have replaced the tq conv as well. He's long gone by the way, so I couldn't ask him.
midias
Jul 7, 2017 09:11 AM
jaweiss
Sep 24, 2011 11:28 PM
327_TPI_77_Maro
Carburetors
May 30, 2006 12:01 PM
Raptor Pilot
Feb 14, 2002 09:06 AM
PimpWillis
Oct 25, 2001 10:53 PM
