What is a good cruising RPM for 60-70MPH?
I cruise at about 2500 at 70MPH...is that a little high? Feels like my tranny is in 3rd all the time like 4th doesn't exist. I have a 91 L98 Formula by the ay. Thanks.
Car: 99 Formula
Axle/Gears: 342
Re: What is a good cruising RPM for 60-70MPH?
I have 3:73s and at 70mph I'm running 2500 rpms too. Next time you're cruising in OD downshift to D to see if the rpms jump up.
I'm at 2000rpm at 70mph, 60mph I'm around 1800rpm. If I shift into 3rd it jumps to around 2500rpm or so. While cruising just try to keep it below 3000rpm, 2000rpm is a good range to keep it at, but if you have an auto and gears well you just have to deal.
ell, the previous owner told me that he had 3.73's put in the rear,but he doesn't know his *** from a hole...he also thought the car was a "rare Firehawk" so I labeled him as clueless from the start...cruising at 70 in 3rd puts the tach at 3400... what i a trying to figure out is if I do or do not have stock gears by determining if my cruising RPM s are too high for what I am driving at in 4th.
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
RPM is fine
I have a 91 Z with a ZZ4 tuned port and 700R-4, 3.23 rear and when i'm at 70 it will cruise at about 2400-2500 which is perfect for that motor. So your rpm sounds right, if you have about 3.23 gears.
Car: 99 Formula
Axle/Gears: 342
Re: RPM is fine
Car: 1989 C4
Axle/Gears: 307
Like Mark said, alot of it depends on tire hight. If you have larger tires you will turn less RPMs for 70mph and if you have smaller tires you will turn more RPMs. The only true way to find out the gear ratio is to pull the covers and post the # stamped on the ring gear, or count teeth.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
