Best flowing SBC Head under $1000
Old Sep 17, 2019 | 04:40 PM
  #51
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Best flowing SBC Head under $1000
Trickflow..forgot about them surprised they still make it. At least someone does..
Old Sep 18, 2019 | 01:22 AM
  #52
NoEmissions84TA's Avatar
My bad. I said AFR, but you guys are correct - Trick Flow makes the small bore aluminum head.
Old Sep 18, 2019 | 06:36 AM
  #53
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Afr i think usedto make a head with smaller valves to fit 305 blocks. You could order the old 190 heads bare and put 1.94 valves in them I think
Old Sep 18, 2019 | 08:21 AM
  #54
Axle/Gears: 4.11
Those were real good heads....one giant heavy hunk of metal!!
If you get those Flotek pay for a better valve job...wow. They are all import castings regardless of where they are assmbled.
Old Sep 21, 2019 | 01:59 PM
  #55
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
#s after some hackery
SF 600
4.125 bore 28"
No pipe on exh
Sure a 4" bore/use of pipe would change things some
100 99.4 94.3
.200 164.7 141.4
,300 222.9 173.8
.400 270.8 201
.500 293.1 216.3
.600 296.2 227.3
.700 299,3 234.1
.800 302.8 239.5
.900 306.3 240.7
Most of the head flow numbers I come across are done on a 4.030-4.060" bore. Hard to compare apples to apples with a 4.125" bore
Old Sep 21, 2019 | 03:15 PM
  #56
Axle/Gears: 4.11
#s vary 3-8 cfm in this case
What Im most interested in is % of gain and where. Was pretty satisfied for a 2.02 valve
Old Sep 21, 2019 | 04:46 PM
  #57
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Probably no better than a 081 or 083 /113 L98 head unless the chamber is significantly better somehow.
Chamber is alot better. Look like baby vortec chambers or 4.3 L99 chambers. I would love to try a pair on a dished piston or even flattop piston 350 to up the compression. Using 5.3 heads worked great on my LQ4 6.0L.
PonyKiller87
Aug 27, 2004 07:37 AM
Sitting Bull
Theoretical and Street Racing
Sep 4, 2002 10:24 PM
