different EGR after swapping trans?
I want to replace my EGR valve to try and pass emissions and I have the OEM part number from the dealer. However, when I went to order it, the widget on the website said the OEM part works for my car if I have an automatic transmission, but not if I have a T5. (The widget also includes an M39 transmission, which says it fits, and an MK9, which says it doesn't fit). Why does transmission make a difference? If it does, which EGR valve do I need?
91 Firebird 305, TPI, VIN F
Engine: 4++,350 & 305 CIs
Re: different EGR after swapping trans?
My parts book is showing
LB9 /M39 uses 17112331
LB9/MK6 uses 17112239
LB9/MD8 uses 17112240
Why it makes a difference I sure don't know.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
M39 is a borg Warner 5 speed
mk6 is a borg Warner 5 speed 2.95 1st
