Best Engine order of assembly
Old Sep 12, 2019 | 10:59 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I've got the factory service manual but I haven't found any order of things to throw my short block together
I could buy a book but that seems almost overkill. Would any of you recommend a particular book?
The long block has been prepped by a machine shop and all parts to match are on hand.
Here's the assembly order I think is optimal...
1. Generally air blow out block, oil galleries, coolant areas, etc
2. Install camshaft
3. Check for bearing gap spec and install crankshaft - also rear seal?
4. Install rings/pistons, check for bearing clearance spec, install piston rod caps
5. Timing set and front seal/cover
6. Heads
7. Lifters, rods, rockers
8. Valve covers
9. Intake and exhaust manifolds
10. Pre-lube
11. Install engine
12. Install accessories...
Old Sep 12, 2019 | 11:10 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Best Engine order of assembly
Give all parts to machine shop and have them assemble short block or even the long block.
Old Sep 12, 2019 | 11:22 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Steve:
If you want to come by I would be happy to layout a procedure for you.
Don>>>
Old Sep 12, 2019 | 11:56 AM
Engine: 350 TPI L98
Transmission: WC T5
Alky, thanks, I could have done that but I want to do this myself. I'll be working with my sons and want them to get their hands on an engine.
Don, I appreciate the kind offer. Although we are both in LA, with traffic, getting down to where you are, for me, is a road trip! I did get the pistons you recommended.
Old Sep 12, 2019 | 11:59 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I install cam last because i degree them in withthe timing chain, so you need the crank and rods/pistons in first
Old Sep 12, 2019 | 03:19 PM
Engine: 350 TPI L98
Transmission: WC T5
That is true but I was thinking might be a good way to protect the cam and cam bearings from dings and dust by having it already in there. Either way I suppose...
Old Sep 12, 2019 | 03:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Could ding it sliding rods down in. Leave the cam in the box til you are ready
Old Sep 12, 2019 | 03:51 PM
Dyno Don's Avatar
Ok, lets try this.....
First get the correct taps and clean out all the bolt holes.
Then blow out everything and take it to get it power washed.
When done with that spray with WD 40 and wrap with a plastic bag.
Keep it wrap at all times except when working on it.
Do not mix up the main caps, they are in order. 12345
You will be installing the main bearings first.
Uppers and lowers are different. get familiar with those so you understand
the difference.
Then you will be installing the crank and checking clearances.
Old Sep 12, 2019 | 05:02 PM
Engine: 350 TPI L98
Transmission: WC T5
Awesome Don, many thanks! I will do all that. Caps are numbered and in place.
Old Sep 12, 2019 | 05:54 PM
Engine: 350 TPI L98
Transmission: WC T5
I found this. It really cool.
Old Sep 12, 2019 | 08:40 PM
69L48Z27's Avatar
Car: 1989 IROC-Z
Engine: 5.7L
Your order is fine, I do the cam later. Clean, clean, clean is the first step. And yes, that rear main needs to go in on the final install of the crank. Don’t forget the oil pump and pan.
Old Sep 15, 2019 | 10:23 PM
NoEmissions84TA's Avatar
2. Install camshaft
6. Heads
8. Valve covers
10. Pre-lube
11. Install engine
Here is a sheet to keep track of things.
Old Sep 16, 2019 | 03:24 PM
BOOT77's Avatar
Read an article with a good point bout the cam not long ago. Test fit the cam 1st to make sure the cam bearings aren't too tight cause it's better to find out before installing anything else in case you need to replace a bearing. I don't assemble engines all the time so don't a have a routine but I usually make a list or I forget stuff LOL
gixxer92
Sep 1, 2015 04:32 PM
SiCkRs
Mar 5, 2009 04:33 PM
IROCKERZ
Apr 26, 2007 08:33 PM
89blackbird
Jan 30, 2002 11:56 PM
Brian Felts
Mar 1, 2001 10:53 AM
