Lower Temp Switch 89 Iroc
Old Sep 19, 2019 | 09:04 AM
kenmaisaano's Avatar
I just got my 89 Iroc running, 305 Dual fans 180 Thermostat. The fan goes on around 230. What switch have you guys had good luck with to lower the temp to around 200? Also I had to use a adaptor in my trick flow heads so it needs to be the stock length or it will be too close to the header.
Kenny
Old Sep 19, 2019 | 11:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Lower Temp Switch 89 Iroc
One of these may fit the bill:
210 degF on, 205 degF off (Wells SW555, Standard TS-136) 3/8 NPT x 14 threads
ACDELCO Part # D1882D {#03053190, 19160820, 3053190, D1874D}
RBob.
Old Sep 19, 2019 | 06:20 PM
Thanks. Just got the TS-136
jay_d
Jun 21, 2010 09:57 AM
AKATDOG
Mar 12, 2010 09:56 AM
89GTA2LV
Oct 24, 2005 03:43 AM
1991rscamarodem
Jul 14, 2002 01:43 PM
Nasty_Bird_'90
Feb 22, 2002 03:55 PM
