whats the operating temp??
hey guys. i have a 90 firebird with an L03. what is the normal operating temp for this? i ask because it's hanging right around 220. seems high to me. thanx
Car: 99 Formula
Axle/Gears: 342
That's about right while in traffic. The fan switch doesn't cut on till about 230*. You could always get a lower stat like a 180* to help some. And a lower fan switch setting. Boy, is it me, or are there a lot of these questions popping up in the last 5 mins.
i odnt think factory switch is adjustable
u can get a switch from summit or someplace like that
or the adjustable one from derale?
i got the 176on-166 off and it worked great
but i think its keeping my car running too cool
so i think im gonna go with an adjustble one
maybe 190 on 175off
oh yeah and the sensor(switch) is located on the pass side head
near the fire wall:lala:
maybe 190 on 175off
be carefull how cool you run these engines, the computer is programmed based on the factory settings. running the engine too cool could cause problems for the computer.
JUST A WORD OF WARNING !!
Is there any corrolation between engine operating temp at your heater? It seems to me, especially when I'm in traffic, that if I have my heater on the 'vent' setting with the temp switch very low, my engine runs up to 15 or 20* cooler.
Does it have to do with circulating air through the engine compartment or is it just in my head?
James
James
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Try replacing the stock 195 degree thermo with a 180 degree one.
My car now runs at about 150 when on the open road, takes alot longer to reach 220 and cools down much faster.....down here in GA. And no problems with the ECM either.
Car: 1989 C4
Axle/Gears: 307
Dont bother to reprogram the ecm if adjusting the fan setting is your only goal. Its cheaper and way easyer to run down to checker/advanced auto and grap an adjustable thermostat switch $18 and just run a wire to the + fan. This way you can controll when the fan comes on and if you leave the ecm controlls intact they will be a good back up system. I set my fan with this adjustable relay to come on a 160* and my car still runs on the 1/4 mark with no air dam 180* thermo but its an 82 and flows a bit more air than most 3rdgens.
Theres a tech artical on this at the main page.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
James
James
-Rich-
Royal_Z
Sep 30, 2015 08:45 PM
