Cranks, but no spark
Old Oct 14, 2019 | 11:15 AM
babadioum's Avatar
Car: 1991 CHEVROLET CAMARO Z28
Engine: 6 LITER after rebuilding :)
Transmission: 700 R4
Axle/Gears: 3.23 / 9:7:1
I'm not getting any spark from the coil-to-distributor cable, that should most probably point to a faulty coil, correct? IF my ICM was faulty, I'd get spark at the coil-to-distributor cable end, wouldn't I? Thanks in advance
Old Oct 14, 2019 | 11:23 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Cranks, but no spark
If the ICM is at fault, there will be no spark at all. If you don't have a factory shop manual, you can find ICM troubleshooting steps here: https://easyautodiagnostics.com/gm/4...ed-icm-tests-6
Old Oct 14, 2019 | 11:27 AM
babadioum's Avatar
Thanks, I'll check it out So then, 1) coil, OR, 2) ICM can be faulty, correct? I mean, assuming ICM is OK, but coil is faulty, I'd still wouldn't get spark, correct?
Old Oct 14, 2019 | 11:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If the coil is bad it can’t produce spark. Go through the trouble shooting link.
start with check power to the icm key on at the pink wire at the icm connector.
Old Oct 14, 2019 | 11:49 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
The coil gets it's signal from the ICM; both must be functional in order to produce ignition spark.
These are old cars, with old wiring and old connectors. Check everything, as directed in the link I provided before you throw parts---and $$$---at the car.
Old Oct 14, 2019 | 11:54 AM
babadioum's Avatar
will do the test
Old Oct 14, 2019 | 12:15 PM
babadioum's Avatar
Here is my dilemma: IF no voltage, pick-up coil is faulty; that's guaranteed, but IF there is voltage, ICM can still be OK while ignition coil is busted, so if there is voltage, the test is ONLY conclusive as long as I guarantee a working ignition coil, correct? So I must check the ignition coil FIRST and ensure it works, correct?
Old Oct 14, 2019 | 01:30 PM
Engine: Lb9
Transmission: M20
The pink wire goes from the ignition switch to the coil then onto the icm. It powers the coil and icm key one engine off.
if that’s fine remove the cap and check for voltage while cranking at the pu coil.
if that’s producing the correct voltage it’s the icm.
Old Oct 16, 2019 | 03:59 PM
babadioum's Avatar
Here is the scoop: the tests clearly exonerated the coil and p-u coil which left ICM as the sole culpable item, so I put the spare to no avail AND the test still pointed to ICM; since two busted ICMs in a row is almost very unlikely and since I was in the midst of a full harness replacement, adapting a swap kit from Payless 60103 which practically becomes an OEM replacement with few ECM and 15-way connector hook-ups based on the OEM mapping (I'll post the work later), I decided to first fix the SES light & ALDL circuitry, crank the engine and get the probable code(s) set so I can accurately pinpoint to the actual problem(s). After wrestling with few hiccups, I got the diagnostics circuitry working and received only the code 46 (VATS): Since the ECM line to VATS sensor was OK, that led me to a unhooked ground off the C7 bulkhead connector which I promptly fixed. Then cranked to no avail, so I circled back to the original ICM, the one I knew it was working before the whole overhaul started since I already identified the replacement also possibly faulty, and voila! Runs like never before
PS: Since VATS was the issue, the fuel was cut off which was probably having an effect on ICM circuitry, at least that's what I assumed for both being indicated as "faulty", but it turned out only one ICM was in fact faulty
Thank you all for your quick and helpful assistances.
mynameisfrank89
Sep 26, 2016 07:59 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
86firebird350
Feb 16, 2013 08:04 AM
Alpha 1 [BAI]
Jan 24, 2007 01:55 AM
