No power to fuel pump
Old Oct 20, 2019 | 02:27 PM
ausedlie's Avatar
Car: 1988 Firebird
Engine: 5.0 tbi
Axle/Gears: 308
On my 5.0 tbi, the fuel pump does not run. The fuse by the battery has been replaced, the relay is new, and the fuel pump is new.
With a test light, I get power to the orange wire, but not the red wire at the relay
The car drove fine before parked 2 months ago, no fuel issues
It definitely seems to be the problem with the red wire, but I don't know where to trace it back to
Old Oct 20, 2019 | 03:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No power to fuel pump
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
The red wire should be a test lead.
Old Oct 20, 2019 | 07:45 PM
ausedlie's Avatar
Car: 1988 Firebird
Engine: 5.0 tbi
Axle/Gears: 308
Shouldn't I be able to see outbound power to the pump on this wire? I tried testing it with the ignition on and the harness plugged in
Old Oct 20, 2019 | 07:59 PM
Engine: Lb9
Transmission: M20
The relay output wire to the pump is grey or it could be tan with a white stripe.
mw92z28anvsry
Oct 13, 2010 05:18 AM
Aaron91RS
Sep 9, 2008 11:20 AM
JohnTheBull
Mar 26, 2007 03:06 PM
crazymex83
Oct 20, 2005 07:47 PM
IROC of 88
Jun 1, 2003 11:45 AM
