RANDOM needs fixed bad
Old May 31, 2003 | 08:35 PM
IROC of 88's Avatar
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
Lately i have been having a problem with my car not starting.... today i tracked it down and found that the fuel pump was not turning on( no fuel at the rails).... so i jumpered a wire from the battery to the power wire on the fuel pump(in the backseat). well it still would not start. about 1 hour later i went back and the car started fine... it has been doing this for about 2 weeks now.... at random times... sometimes with the engine cool, sometimes hot, sometime medium.... just random...
could the fuel pump just be going out, could it be loose wires?( if so, i would think the car would shut off while i was driving sometime, which it has never done) sometimes it just won't start... it turns over fine, and i am getting spark... it is fuel pump related some how.... but my fuel pump is only about 10 months old
Old May 31, 2003 | 09:05 PM
25thanniversZ's Avatar
check the fuel pump relay located on the firewall,and the fuse by the battery
Old May 31, 2003 | 09:15 PM
IROC of 88's Avatar
Car: 1988 IROC
oh, btw i bought a new relay today, before i posted, and the fuse is good too
Old May 31, 2003 | 09:30 PM
you jumped the wire straight to the pump wire and still no cycle??? might be it
Old May 31, 2003 | 09:58 PM
IROC of 88's Avatar
Car: 1988 IROC
yes, i jumed it strait to the power on the pump, it is in the back seat of the car..... but a hour later it started fine, and it starts fine now.... but at anytime can stop again
Old May 31, 2003 | 10:02 PM
you might want to check the knock sensor, it is in play with the fuel pump,if the engine starts knocking it sends a signal to the pump and kills it to keep from engine damage. well in lamins terms
Old May 31, 2003 | 10:25 PM
IROC of 88's Avatar
Car: 1988 IROC
it has never died while it was running, just sometimes it will not start.... do you think it could still be the knock sensor?
Old May 31, 2003 | 10:29 PM
one of those possabilities,there strange , some cars wont run without them some such as mine will
Old May 31, 2003 | 10:53 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Well when it doesn't want to start, bang on the tank a bit to try to coax the pump into running. That worked like a charm when my truck's fuel pump started to choke.
Old May 31, 2003 | 10:55 PM
have you replaced the fuel filter?
Old May 31, 2003 | 11:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Uhhhh...no.
Please refrain from from posting your assumptions on how things work, you could send those who have less knowledge than yourself, on a wild goose chase.
Old May 31, 2003 | 11:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Your sure the problem is fuel pump related?
Turn the key on, do you hear "whine" of the fuel pump running?
If yes, then no need to diag the fuelk,pump, your problem lies elsewhere.
When you "direct power" the pump, does the pump "whine" and turn on? if so, your problem isn't with the pump, per say...could still be a pressure problem with the pump, but you'll need a gauge to be sure.
Old Jun 1, 2003 | 01:03 AM
no reason to be rude and down me....I know what im talking about,just tired as hell and cant really seem to put things in words at the moment so it came out as if I didnt have a clue and I do
Old Jun 1, 2003 | 01:37 AM
IROC of 88's Avatar
Car: 1988 IROC
I have replaced the fuel filter, and there is no "whine" as you wanna call it...
I know it is not turning on.... but i am not sure why, cause tongiht i started it up and drove it around for about 2 hours.... then it suddenly died.... I called the wrecker... got it towed home and it started right up and drove it off the truck.
I have also tried banging on the tank... lol.... no help, but it made me feel better
Old Jun 1, 2003 | 02:17 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
LOL, the actual jaring that the car is taking under tow got the pump to start. I use a really large rubber mallot when I suspect a bad fuel pump. A couple a good hard raps while someone cyxles the key will usually make it start. If your jumping the correct wire a little before the tank then it's got to be either a bad pump, broken wire or bad connection or a loose ground. There should be a connector at the back of the tank under the car that will put you closer to the pump for testing. If no fuel but 12 volts and the ground is good, needs a pump.
Old Jun 1, 2003 | 03:54 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
You have to jump the relay from the underside, at the back seat..the tank side of the relay..does that make scence. If you are tyring to jump it from the interior side of the relay, the relay may still stop the power from reaching the pump.....Sounds to me like you need a new fuel pump....just a matter of time before it stops all together...
Old Jun 1, 2003 | 11:45 AM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Exactly. When my truck wouldn't fire I got my father to sit there cranking it while I looked at the injectors (TBI). No fuel. So, with him still cranking I gave the centre of the tank a light tap with my foot and it fired up almost instantly. It had to be right in the middle of the tank though, directly under the pump.
Cornholio7979
Sep 20, 2018 02:31 AM
86IROC112
Apr 9, 2016 10:20 PM
dyeager535
Aug 28, 2015 08:10 AM
fonzie85
Aug 13, 2015 11:50 AM
