Pump To Carb Fuel Line...
Old Oct 29, 2019 | 02:15 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Does anyone have a picture of their Factory L-69 fuel pump to carb fuel line?...
Old Oct 29, 2019 | 06:27 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Pump To Carb Fuel Line...
Old Oct 29, 2019 | 07:48 PM
T.L.'s Avatar
Thanks. I guess I should have been a little more specific. I'm looking for a picture of the fuel line installed on the engine...
Old Oct 29, 2019 | 09:57 PM
Unfortunately mine cracked and had to be replaced about 30 yrs ago.
What part are you particularly concerned about? Maybe we can help you solve whatever you want to solve by some other means.
Old Oct 29, 2019 | 10:38 PM
T.L.'s Avatar
Okay, I have a brand-new fuel line just like the one in the picture above, and I certainly know how to put threaded compression fittings on.
I don't remember how the original line was routed. This new one fits only if it is is run between the water pump and timing cover. Is this correct? I guess I could have made it easier by asking this in the first place, but I like visual aids....
Old Oct 30, 2019 | 03:27 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
some go behind the pump, some go around it. I've seen both.
Old Oct 30, 2019 | 06:46 AM
T.L.'s Avatar
Okay, that helps. This line is supposed to be for a '84 L-69 ...
Old Oct 30, 2019 | 09:09 AM
naf is correct; both routings were used.
Seems like my 83's original one went behind the WP as well. I seem to recall dumb-a$$ing out on myself one time and having to take the WP back off to put the line back on after doing something or other to it.
Whichever one fits your line to your car, is probably the one it was designed for.
Compression fittings are a REAL BAD idea on fuel lines.
Old Oct 30, 2019 | 09:42 AM
T.L.'s Avatar
Maybe "compression" isn't the right word. They're double flare fittings like brake lines...
Old Oct 30, 2019 | 10:06 AM
gt4373's Avatar
All L69 Third Gens I've Seen At Car Shows/Cruises Had The Fuel Line Behind The Water Pump, My Car Included.
Old Oct 30, 2019 | 12:30 PM
T.L.'s Avatar
Thanks for the help, guys...
Old Oct 30, 2019 | 05:51 PM
Yeah, there's a world of difference between an inverted double flare fitting, and a compression one...
FastPhoenix84
Carburetors
Jul 12, 2008 06:42 PM
DTL504
Carburetors
Jan 23, 2004 10:03 PM
Fast86TA
Carburetors
Oct 25, 2001 02:20 PM
