No voltage at cold start switch
Car: 88 camaro iroc
Engine: 5.0 TPI
Transmission: 5 spd mannual T5
Axle/Gears: 3.27/ 9 Bolt
Recently my 88 tpi iroc has been having rough idle when cold or first start up in the day, it fires right up after that without the rough idle through out the day. I did some research and one of the possibilities could be a bad cold start valve. The first thing I checked was voltage at cold start valve (purple wire) when turning on the car and there is no voltage. I checked for voltage at the cold start switch also no voltage. (I checked them in the morning when engine is cold). So, does anyone know where these two parts get voltage from?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No voltage at cold start switch
The timer switch gets power from the starter in crank .
you might check your starter connectors. You can always upgrade to 89 $6e mask and get rid of the ninth injector.
Engine: Lb9
Transmission: M20
1986iroc350
Jan 25, 2015 02:05 PM
