Edelbrock runners vortec heads
Old Nov 28, 2019 | 07:36 PM
HellNauman's Avatar
Hello all,
I have vortec heads with a sd3816 manifold on my 91. I'm looking into aftermarket runners. Does anyone know if edelbrock runners will bolt straight up, need modifications, or not compatible at all? If not, are there any runners you would reccomend?
Old Nov 29, 2019 | 01:17 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Edelbrock runners vortec heads
Any of the aftermarket runners are similar. You can use 85-88 runners on 90-92 cars with a couple small mods that aren't permanent. AS&M Siamese and large tube runners are on the top side of performance and price.
Old Nov 29, 2019 | 01:27 PM
HellNauman's Avatar
What mods? Trying to find out before I buy and potentially waste money. I appreciate your help
Old Nov 29, 2019 | 01:45 PM
TTOP350's Avatar
Block off the cold start inj and need a pipe plug in the small tube on the driverside to prevent vac leaks.
No issues if you buy the correct year runners
Old Nov 29, 2019 | 02:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I ran a set of fully siamesed SLP runners.
Old Dec 2, 2019 | 10:05 AM
HellNauman's Avatar
Any issues with fitment over larger injectors? I heard there could be some trouble. I have 24# injectors
Old Dec 2, 2019 | 10:36 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Contact southbay to see about the injectors fitting the base.
I forgot if you have b3s but you might have to have ones without there press on adapters. Curious to know
Old Dec 2, 2019 | 10:38 AM
Engine: Lb9
Transmission: M20
@ChevyTycoon just installed a set of as&m / tpis runners and had a issue with them fitting the vortec base.
Im not sure what he did to fix it grind runner flanges or what.
Old Dec 2, 2019 | 10:48 AM
TTOP350's Avatar
I'm cut from a different cloth lol, I just expect to have to mod aftermarket parts a bit to make things work.
Ludo
Apr 6, 2009 11:37 AM
bes217
Mar 25, 2003 12:22 PM
My85TA
Aftermarket Product Review
Sep 2, 2002 07:22 PM
Gta-Paladin
Jan 8, 2002 06:57 PM
