Lifting engine/trans from TPI fuel rail mounting bolt holes?
Old Jan 23, 2020 | 10:59 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Those four elevated fuel rail bolt holes look exceptionally strong for holding a fuel rail down. I was wondering if I can lift from them. Anyone done this? I am going to be lowering a 5.7 and T5 assembly back into the car. I want to put the intake manifold on outside the car.
Old Jan 23, 2020 | 11:01 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Lifting engine/trans from TPI fuel rail mounting bolt holes?
I believe you can, tpis use to make a happy hooker that went to the fuel rail bosses.
Old Jan 23, 2020 | 11:08 AM
Engine: 350 TPI L98
Transmission: WC T5
Yep. I saw that. Just wondered if that was for those holes as well. It's a lot more fun installing an intake manifold on the stand.
Old Jan 23, 2020 | 11:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Eh those are some small threads. I havent done it tho. I have chains to the 4 corners of the heads on a load leveler
Old Jan 23, 2020 | 11:48 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Don't know about using the fuel rail mounting holes but I've pulled many engines using carb mounting holes. Had a plate that bolted down on the carb mount holes and had a u-bolt welded to the plate to hook onto.
Old Jan 23, 2020 | 12:19 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You will probably be OK using the fuel rail bolt holes,..... but WHY RISK IT ?? If just 1 hole gives out not only is the intake ****ed,... but imagine the damage caused to the engine if it falls,... or the damage to the car if the engine falls on it.
Don't do it,........ There are PLENTY of holes in the heads that you can bolt a chain too.
Old Jan 23, 2020 | 01:54 PM
Drew's Avatar
Never seen the side of one of those bosses break out, I'm guessing? The problem isn't the threads. The problem is the aluminum around the threads is thin. Those bolts are only to keep the fuel rail from moving around, they're not really up to lifting the engine.
If you want to bolt stuff together before dropping in the engine, you could always go in from the bottom.
Old Jan 30, 2020 | 04:46 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I never thought of using those holes to lift the motor. But I checked out the TPiS website and they still sell the "Happy Hooker" for $74.95. Drilled to work with TPI, LT1 and LS motors.
Galaxie500XL
May 2, 2016 07:08 PM
DAVECS1
Alternative Port EFI Intakes
Feb 28, 2007 06:31 PM
91FormulaCRAZY
Aug 26, 2002 07:11 AM
WaynesRS
Apr 3, 2002 09:17 PM
