SA versus NonSA Rockers
Old Jan 30, 2020 | 01:07 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
I am building a 1996 5.7L Vortec. The heads are done with a 0.495 lift, threaded studs, and I plan 1.5 roller tip rockers. I have guide plates. Is it better to use Self Aligning roller tip rockers with the guide plates or is that over kill and just need to use Non Self Aligning roller tip rockers?
Thanks.
Old Jan 30, 2020 | 04:05 PM
Drew's Avatar
Re: SA versus NonSA Rockers
Typical wisdom has always been non-self aligning rockers with guide plates. Logic being that both will result in the two guides fighting each other. FWIW, second hand info, haven't tried it therefore it has not been my funeral.
Old Jan 30, 2020 | 04:45 PM
NoEmissions84TA's Avatar
Drew is correct. Trying to guide with two methods will fight each other, and bad things could happen.
Also, you cannot use SA rockers with solid lifters, either flat tappet or roller.
linkz761
Mar 30, 2005 11:54 PM
83ho86tpi
Aftermarket Product Review
18
Feb 22, 2005 10:03 PM
NHRAK188
Jan 27, 2004 05:01 AM
Zepher
Aug 22, 2002 12:28 PM
slayer2000
May 14, 2002 10:22 PM
