Alaskan 82 Firebird not starting!
Old Mar 3, 2020 | 08:51 AM
AKFirebird's Avatar
Hello everyone, I just purchased a 82 Firebird here in Alaska! Picked it up for $300. Previous owner said he thinks the starter went out so he bought a starter to go with the car but didn’t install it. Has a brand new Edelbrock Carb on it along with a New air filter housing. Also came with 2 brand new headlights. After getting the car to the house and looking over the car I have noticed that a lot of the fuses are missing. So naturally I replace the ones that are missing and the ones that wasn’t. In doing so I noticed that the fuel pump fuse location along with some others have no wires running to the fuse box and there is no where for a fuse. I’m no electrician but obviously that’s wrong. I also noticed that I assume where relays go for the IGN and a few other things was not there. Upon further inspection of the car the neutral safety switch has some wires cut as well. After doing some reading I’m assuming they had tried to bypass the NSS. When I turn the Key on I get dash lights, headlights, brake lights, and a dome light. And the push button to open the trunk works. Other than that I have no crank or anything. I’m new to the Firebird world and older car world but would consider myself handy as far as working on things go. Any help or shared knowledge would be greatly appreciated
Old Mar 3, 2020 | 09:33 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Alaskan 82 Firebird not starting!
I'm not so certain that an '82 305 should even have a fuse for the fuel pump...I don't think they went to electric fuel pumps until '84 or so, and IIRC, that was only for the 305 HO, and even then, it was more of a "helper" pump as they still had a mechanical fuel pump as well. Perhaps it was thinking ahead on GM's part to have a slot in the fuse box for an electric pump, knowing that they'd probably need it later on?
Have you checked the starter wires with a multimeter while trying to crank the car to verify that there's no power going to them? I'd probably start there.
Old Mar 3, 2020 | 11:21 AM
AKFirebird's Avatar
Thanks for the reply! I will certainly try that once the snow melts or I can get it into a garage! You could be right but I don’t know why there would be a fuse location if one wasn’t needed? Can you point me in the right direction of what relays to use for the IGN and other relays that are missing in the fuse box?
QUOTE=navy02ws6;6357279]I'm not so certain that an '82 305 should even have a fuse for the fuel pump...I don't think they went to electric fuel pumps until '84 or so, and IIRC, that was only for the 305 HO, and even then, it was more of a "helper" pump as they still had a mechanical fuel pump as well. Perhaps it was thinking ahead on GM's part to have a slot in the fuse box for an electric pump, knowing that they'd probably need it later on?
Have you checked the starter wires with a multimeter while trying to crank the car to verify that there's no power going to them? I'd probably start there.[/QUOTE]
Old Mar 3, 2020 | 01:29 PM
A CFI car would have had an electric fuel pump, hence the need for that fuse position.
I'd suggest looking at the fusible links, down at the starter.
Old Mar 3, 2020 | 03:43 PM
AKFirebird's Avatar
So do I need a fuse for the fuel pump or no? And I’m going to try and take a look at that today but I don’t have a garage and it just snowed around 1.5FT here in Alaska. Weather isn’t helping the itch to get this thing running!
Old Mar 3, 2020 | 04:42 PM
AKFirebird's Avatar
Also the IGN slot in the fuse box is empty is it a relay that goes there or what do I need to plug in to that because it’s obviously not a fuse!
Old Mar 3, 2020 | 06:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
only Crossfire injection(CFI) cars has electric fuel pump in '82,standard carb. engine just used engine mounted mechanical pump.The empty "IGN"slot you mention is likely where options could be plugged in-I'll look at my '82 and see what is there
KellyLauren
Apr 19, 2009 08:37 PM
mudbucket72
Apr 19, 2009 10:22 AM
WaFFLesZ28
May 14, 2005 06:12 AM
GTA88
Aug 17, 2003 02:26 PM
crazyta1989
May 21, 2003 02:14 PM
