Power steering brackets
Old Mar 19, 2020 | 10:04 AM
Tidan's Avatar
Does anyone know if these two brackets can be removed or are they necessary for the PS pump? I no longer have AC and am installing headers and would like to clean up the engine/bay.
Thanks!
Old Mar 19, 2020 | 12:22 PM
Re: Power steering brackets
Yes they are needed.
However... you could cut off the top of #1, maybe round it over somehow or something.
Old Mar 19, 2020 | 01:31 PM
Tidan's Avatar
Bummer. Thanks.
Any aftermarket brackets that would work that you're aware of?
Old Mar 19, 2020 | 01:52 PM
Not that I know of. But I've never researched it.
Might be worthwhile looking into converting it to serpentine belt. Many more options that way.
Old Mar 19, 2020 | 07:30 PM
NoEmissions84TA's Avatar
Here is he bracket that the non_AC cars used:
Old Mar 19, 2020 | 08:04 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Alan Grove makes some nice "stock" looking v belt brackets too.
http://www.alangrovecomponents.com/
Old Mar 19, 2020 | 08:11 PM
Tidan's Avatar
Thanks NoE, that's a huge help! I'm going to look at that bracket and see if I can fab one out of my current collection.
FRMULA, those brackets look interesting too.
Old Mar 19, 2020 | 08:56 PM
Part 14101199 Has Been Superseded
  • 00469560 is interchangeable with 14101199 since August 1, 2000 for the U.S. market;
  • 14101199 is discontinued since November 1, 1995 for the U.S. market.
Cars 14101199 bracket Fits
Camaro 1982...1992
Caprice 1982...1990
El Camino 1982...1988
Monte carlo 1982...1988
Chevette 1982...1987
Berlinetta 1982...1986
Impala 1982...1985
Citation 1982...1985
Malibu 1982...1983
  • Chevrolet
  • Chevrolet Trucks
  • Pontiac
  • GMC Trucks
Parts Related To 14101199 bracket:
Old Mar 19, 2020 | 09:18 PM
Tidan's Avatar
Great find NoE, thanks!
Old May 11, 2020 | 05:01 PM
Tidan's Avatar
Do you know if this lower bracket can be omitted?
Old May 11, 2020 | 05:32 PM
Not really. The PS pump needs it. Or at least, what it does. The no AC version has the same feature but implements it differently.
Old May 11, 2020 | 05:41 PM
I can't say for sure, but IIRC, there is an additional stud on the back of the PS pump that goes in the slot in that bracket for belt adjustment. It's a real PITA to get to also. Since you no longer have AC, then you can remove bracket #1, put a thru-bolt here, and cut the top part of bracket #2 off. Keep bracket #3 and #4 in place.
Old May 11, 2020 | 06:17 PM
Tidan's Avatar
Excellent! Thanks guys. I've chopped the AC bracket down, fabbed up a spacer roughly the height of the manifolds to remount it to the headers.
Old May 11, 2020 | 06:38 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
thats exactly what I kept telling you to do in our Private Mesages!
Old May 11, 2020 | 08:18 PM
Tidan's Avatar
Thanks IrocZ. I was hoping to save my AC bracket for future use or to pass on to someone whom needed it, but that's no longer an option. ;-)
chirrrs
Jun 10, 2013 04:45 PM
therckid
Nov 12, 2004 04:04 PM
