transmission problem? or rear end problem?
Old Apr 12, 2020 | 10:38 PM
garyww242020's Avatar
i have a 1989 camaro 1962 327 with a 700r4 transmission. all forward gears are great but when i put it in reverse and tap the gas my rear end feels like it shakes or slips. not sure what is going on only started that after engine swap/rebuild. any help is much appreciated.
Old Apr 13, 2020 | 07:46 AM
Re: transmission problem? or rear end problem?
Rear ends don't "slip", so that's not a possibility. About the only thing about the rear that could do that, is if the pinion nut has backed off SO FAR that the pinion gets sucked into the housing SO FAR that it hits the carrier. But you'd notice an extreme amount of noise coasting in forward as well.
More likely it's your transmission.
KC_Reaper
Oct 30, 2012 08:14 AM
dannyvera778
Oct 22, 2009 11:37 AM
IROC of 88
Oct 22, 2007 06:25 AM
JungleMan
Dec 1, 2004 02:29 PM
