Rear end problem
Old Sep 24, 2002 | 03:40 PM
IROC of 88's Avatar
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
Rear end problem
when I turn and accelerate... the rear end seems to lock up and make an EEHHNNNNEEHHH noise.... i am quite certain this is bad, but what is the problem, and what should i do to fix it
Old Sep 24, 2002 | 04:27 PM
ede's Avatar
ede
first thing to do is not to drive it any more. second thing would be to pull the cover and do a little inspection work. i'd guess the spider gears are shot.
Old Sep 24, 2002 | 07:55 PM
Redliner's Avatar
Car: Tahoe
ditto
Old Sep 26, 2002 | 10:54 PM
laiky's Avatar
spider gears.
Old Sep 27, 2002 | 09:25 AM
IROC of 88's Avatar
Car: 1988 IROC
I do not think my rearend has spider gears.... i think it has littel clutches or something like that.... it is a 2.77 posi BW
Old Sep 27, 2002 | 09:46 AM
laiky's Avatar
it has spider gears too
Old Sep 27, 2002 | 01:06 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
You have the borg warner 9 bolt and it has 4 spider gears. Sounds like the posi unit is wornout (It will have to be taken apart to determine specifically what, but probably the cones are worn out and took to carrier halves with it). Depending on how bad it is, it can be rebuildable but will probably be cheaper to buy a new one.
I have new posi units available (series 3 only). More inforamtion is available at www.9bolt.com
Miles
Diff Solutions
Old Sep 29, 2002 | 01:41 PM
IROC of 88's Avatar
Car: 1988 IROC
got some good news, but it kinda makes me look stupid.... I checked my tranny fluid and it was about a quart and a half low,,, i added the fluid and it fixed the problem with my rearend
Old Oct 11, 2007 | 07:53 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: Rear end problem
Old Oct 11, 2007 | 11:50 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2.
Old Oct 20, 2007 | 12:30 PM
carl_318@hotmai's Avatar
thats weird that that would fix it I have the same problem with my 87 ,with my 9 bolt posi and my tranny fluid is fine. Ive narrowed it down to needing a new posi. It also seems to be bad when its warm out or when the rearend gets real warm after driving it for ahile.
Old Oct 22, 2007 | 06:25 AM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
