when do u replace the pigtails?
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
when do u replace the stock pig tails for the IAC valve.. my car is at high idle and i never replaced the IAC valve. Im looking at buying ( ACDELCO 217437 {#25527077} MFI; USED W/ 12085506 ) and it says it used with 12085506 so does that mean i gotta change both parts?
Re: when do u replace the pigtails?
Shouldn't require any wiring changes. You should first set minimum idle air and TPS voltage before you load up the parts cannon.
GD
GD
Engine: V8 305
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If the plastic is just broken replace it
https://www.ebay.com/itm/K4-4-Square...cAAOSwqohdjVdy
https://www.ebay.com/itm/Delphi-Pack...4AAOSwgotcR13F
Stock is fine. Also they can be cleaned. It's just a stepper motor with a threaded pintle. Clean and lube the threads.
GD
GD
