Power gains for new build
Old Apr 30, 2020 | 01:31 AM
Ramirez18's Avatar
Hey guys , hope you can help me out. Finally got my 89 iroc z TPI running and I’m looking for some quick ways to add some power to it. Looking into cams, headers , manifolds but I’ve seen there’s debates between sticking with the TPI or going with the HSR . Anyone know what would be a good way to get some kick outta this thing.
Old Apr 30, 2020 | 01:42 AM
GeneralDisorder's Avatar
Re: Power gains for new build
You have a power goal in mind?
Things you can do "quickly"..... it's all relative I suppose but the quickest would probably be a full tune up followed by headers and y-pipe.
Gears and torque converter make an enormous difference in the off the line feel and will be needed with more motor anyway.
Cam, heads, intake are next.
GD
Old Apr 30, 2020 | 01:47 AM
Ramirez18's Avatar
GD
For now just trying to wake up the motor and get a decent amount of power while not blowing anything up. I’ve been looking at headers , cams , intake manifold and TB but I’m not sure as to which setup would be the best option. I’ll also keep the gears with the torque converter in mind as I get more power out of the car.
Old Apr 30, 2020 | 01:52 AM
Keep in mind that anything you do to the motor beyond headers WILL ABSOLUTELY require tuning to get decent results. So focus on how you plan to accomplish that aspect first. It's a much larger challenge than actually buying and installing a camshaft or heads. Tuning solution first. Headers, y-pipe, exhaust, gears, and converter while you get up to speed on tuning.
GD
Old Apr 30, 2020 | 11:06 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
GD
^^^I have setup a full bolt on LB9 car that was very quick with the stock L98 cam, stock heads and stock TPI with a ported plenum, ported stock lower intake and AZ Speed and Marine runners. Got it into the lower 13s in the 1/4. Headers, magnaflow dual cat Y-pipe, 3" cat back, new higher rate valve springs, 1.6 rockers, 2,400 stall converter and 3.42 rear. Tuned with TunerProRT. Was very straight forward to tune with the stock cam.
camarotucker
Northern Great Plains and Rocky Mountain
May 1, 2017 11:03 PM
Rock-Bert
Jan 7, 2008 11:39 AM
blaze1
Aftermarket Product Review
Feb 6, 2004 05:35 PM
Halberto45
Mar 25, 2002 07:23 AM
