After crank issue!
Old May 18, 2020 | 04:02 PM
MacRocZ's Avatar
Car: 1989 IROCz T-top & 1988 Convertible
Engine: 350 TPI x2
Axle/Gears: 3.73/4.11
After crank issue!
So this has been an on going issue for a few weeks to month's time. Anytime I crank my 89 IrocZ 350 TPI, it will crank up. More often than not, it will act as if it's flooding when i apply the slightest pedal from initial crank. I'll leave the gas pedal alone. After a about a minute or less, the motor will choke as if its about to die, spool back to operating rpm (600) and then its fine. Drives normal. Accelerate normal.
Things I've replaced
MAF
Vacuum lines at T connector to EGR Canister at the nose of the car (dry rotted)
Things I've tested
TPS - 0 volts at ignition "on" (the Volt reader doesn't read points apparently) 4volts at WOT
I've tried to think logically as to what would cause this problem, but at a wits end. Now I'm here to see if anyone else had this issue, at what could possibly solve this issue..
Shes my daily!
Thanks in Advance and After
Old May 18, 2020 | 04:10 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: After crank issue!
Gotta start somewhere , and since it sounds like it could be fuel related I'd start with checking the fuel pressure .
Old May 18, 2020 | 04:34 PM
MacRocZ's Avatar
Engine: 350 TPI x2
Now hypothetically speaking, if it's due to the fuel pressure, would it be as "simple" as replacing the fpr?
Also, if it was fuel pressure, wouldn't that mean it should do it thru out the time i'm driving and not just after initial crank?
I'm not only trying to solve the problem, but also understand why its happening lol
Old May 18, 2020 | 04:36 PM
MacRocZ's Avatar
Engine: 350 TPI x2
Also, I had future plans on buying one of those fancy ALDL connectors to USB and using my laptop to monitor whats going on with my motor. Would that data it log be able pick up on fuel related info?
Zokal
Jul 26, 2021 07:18 PM
SheldonZ28
May 27, 2009 02:46 PM
86z28iroc-z
17
Feb 19, 2008 08:56 PM
quisterio
Jan 30, 2007 11:53 PM
david roush
Oct 16, 2003 07:23 AM
