Accessory belt orientation, how did the factory do it?
Old May 15, 2020 | 04:20 PM
GMP318's Avatar
When these cars were built at the factory were the labels on the belt facing forward where you can read the labels from the front of the car or where the labels facing backwards? Thanks.
This is on an 87 Firebird with LG4 (305 4bbl) engine.
Old May 15, 2020 | 04:30 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Accessory belt orientation, how did the factory do it?
They were orientated in a way that made them readable right side up when facing the engine from the front of the car.
Old May 16, 2020 | 08:01 PM
dan5's Avatar
Car: "Barn find" 1985 IROC-Z
There might have been a specified direction on these cars, but I can't say for sure. It would take someone with a PAD (production assembly document) from the assembly plant / engine dress line. In recent years, I worked with accessory drives and with the team that likely designed the ones for the 80's Camaros. I can tell you that in the last 15 years I've never seen a direction specified to the assembly plant. It wasn't a critical item. When I went to the plant for assembly trials, this was never a topic of discussion. The goal was to get the belts on and properly tensioned.
Old May 16, 2020 | 09:29 PM
GMP318's Avatar
The reason why I asked was that I was getting ready to change out the accessory belts when I noticed that the power steering belt was the original A/C Delco one.
This one has never been changed. Been on the car since 87. We are the original owners of the car. Noticed that the orientation of the AC Delco label on the belt was facing towards the engine block. So, if you look at it from the front of the engine , it looks upside down.
Who knows; maybe thats the way they installed them at the factory, with labels facing the engine block.
Old May 17, 2020 | 09:02 PM
dan5's Avatar
I think that it is random, just based on how the assembler picks up the belt. GM has standards for underhood appearance and I was never challenged (in recent years) by a vehicle engineering team for having a belt on "backwards". I really don't expect it was different in the 80's.
Old May 18, 2020 | 04:28 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
From the FWIW department....
The '86 Camaro AM doesn't specify that the belt ID to be installed in a specific orientation. It make zero reference to it. I install them, "right-reading" when I'm standing in front of the engine.
I would bet money that the Corvette guys/gals would know.
Old May 18, 2020 | 01:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Put mine on facing forward so you could read it with hood open
Old May 18, 2020 | 07:07 PM
BIRD91ZRAG's Avatar
FWIW, when I judge the 68-72 Chevelle engine compartments at the MCACN show in Chicago, I don't care which way the belts go on as long as they're the right ones...
ScorchedBird12
Apr 7, 2012 03:36 AM
bobert
Feb 3, 2007 02:24 PM
1989karr
Dec 19, 2005 01:02 PM
