1983 z28 dead after streets flood
Old May 28, 2020 | 09:07 AM
randallp504's Avatar
Car: 1983 Camaro Z/28
Engine: 305 HO
Transmission: 700r-4
Axle/Gears: stock
Looking for some tips on where to start looking/troubleshooting. My neighborhood streets flooded up to our doorstep about a week ago (15 minutes from New Orleans) and my car was backed into driveway. I looked in her after the water went down and the inside was dry, It got up to the rockers. Anyway I went to put it back in garage and it?s doing nothing. Battery is charged, terminals tight and corrosion free. Headlights, Dome lights, under hood light, ignition nothing coming on. I took terminals off double checked charge and even put charger on battery when it was in the car nothing. Any tips help. Thanks, Randy
Old May 28, 2020 | 09:52 AM
Re: 1983 z28 dead after streets flood
Check the fusible links at the starter.
Old Jun 4, 2020 | 11:56 PM
Stallion's Avatar
Check the fuse panel under the steering wheel and see if any blew out. If it did, there might be an exposed wire that got shorted.
Old Jun 6, 2020 | 07:27 AM
Vader's Avatar
Plain water is not sufficiently conductive to cause overcurrent (shorting) problems at 12V. However, all the items which may have been underwater are suspect due to contamination. For example, there is frequently a lot of carbon and copper accumulated in a starter motor. If that were to go underwater and the conductive material became suspended in water then was allowed to settle into the bottom of the motor, that could cause shorting problems.
The same phenomenon can occur with other things which went submerged, and this doesn't even consider the silt and contamination carried by flood waters, Get out your meter, your schematic, and galoshes, and start checking from the battery onward.
Convoy25
Mar 30, 2009 10:31 PM
socalred86z28
Oct 8, 2008 03:10 PM
Bad-Newz
Jul 24, 2007 03:00 AM
kiztope
Oct 15, 2002 08:05 PM
iroczul8r
Jun 2, 2002 12:39 PM
