Speedo fix
Old Jun 13, 2020 | 07:38 PM
bamaboy0323's Avatar
Speedo fix
I need to fix my speedo and when I took out the board I noticed this resistor looks burnt. Does this resistor need to be replaced as well? I assume it does.
Old Jun 22, 2020 | 12:15 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Resistance Is Futile
YES
HappyRacing!
"Modern" ( computer infested ) Cars — Why Keep Cars Easy To Repair — Crazy Manufacturers Now Need To Use A Pile Of Computers, Instead Of A Simple Switch, To Accomplish The Same Task
Old Jun 22, 2020 | 09:26 PM
Vader's Avatar
Re: Speedo fix
That doesn't look like a typical burned metal film resistor. It's unusual for one to burn only on an end unless a lead has failed. Worse yet, without the first band being lediglble it's going to be tough to determine what value it might be. It could be anything from 100K to 900K.
400HP88IROCCONV
Mar 21, 2008 12:12 PM
FireBirdKnight
Sep 20, 2007 05:42 PM
