drivers side kick panel
Old Aug 26, 2020 | 02:53 PM
wayshegoes's Avatar
Car: 1988 GTA Trans AM
Transmission: 5 speed
i have noticed that if i kick the drivers side kick panel my power antenna cyles on and off, goes up and down, same thing that happens when i connect battery after storage, is there a ground in the kick panel? bad wiring, just asking before i figure out how to get myself crammed in the small space, not as easy as use to be, sucks getting old
Old Aug 26, 2020 | 04:55 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: drivers side kick panel
The fuse panel and main wiring is down there, very near the kick panel. It is possible something is loose
Old Aug 31, 2020 | 09:16 AM
wayshegoes's Avatar
so i managed to squeeze down under the drivers side dash and it found the problem, the wire bulkhead, that goes through the firewall, i have a red wire, A5 or A4, cant remember, it is a power distribution wire, if you wiggle this wire where it connects the power gets cut off, i will have to take a picture of the wiring schematic i was looking at
can i disconnect this bulkhead to re-pin the wire? if so how does one remove it
trnsam78
Nov 26, 2006 10:44 PM
Madcrazy
Aug 2, 2006 09:00 AM
Dirrty_Bird
Jun 27, 2006 08:37 PM
RamoneZ
Aug 17, 2004 07:18 PM
