How to clean out fuel lines?
Is there a good but somewhat easy way to clean out fuel lines? Car sat for several years. Cleaned tank, replaced pump and filter. I was going to unhook lines back of car and blow out lines, but thought that might just push varnish more to regulator and injectors. Any advice
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: How to clean out fuel lines?
Additionally, you might consider replacing the brake lines as well.
Don’t laugh I’m a novice here. Now when you say both ends. You mean the front and the back? I was hoping I could unhook lines at back of car- supply line and then return line and use air into one and have it come out the return line. Would this just clog the regulator with more junk? Is there a easy access to unhook lines up front or are they under the upper intake. Really don’t want to get that deep into unless I have to. Could I hand pump some cleaner into the supply line have it make the rounds, clean and come out the return line?
On my '86 TPI both the lines disconnect right up there in the front of the intake right below your air duct where your MAF sensor sits. Worth a shot cleaning em out first.
Car: 1986 IROC Z
Engine: 5.0 TPI
IMO, the best plan is to disconnect the feed as well as the return line at both ends, and blow them out individually, again, catching the result in a jar so you can inspect any contaminant(s).
Car: 1985 IROC
Engine: 350HO
Axle/Gears: 10 bolt 3.23 limited slip
I'm in the same predicament as you. Car sat for like 10 years and the fuel system needs to be cleaned. I plan on replacing the fuel lines to eliminate any possible issues (especially a leak in the line that could catch fire). Keep a fire extinguisher close by just in case.
BOTTLEDZ28
Jul 22, 2001 10:15 AM
