Loud knocking at idle only 1988/305/TBI
Car: 1988 Chevrolet Camaro
Engine: 305/TBI
Axle/Gears: stock 7.5"
So the car fires right up and knocks like hell while idling (+/-700 rpm) when given any amount of throttle even a 100 rpm bump with the pedal it goes away and runs smooth as a kitten. While driving it runs beautifully until it returns to idle (I e. Redlight) and the loud and I mean loud knocking returns, and vanishes again when I go.
Any ideas?
Any ideas?
Re: Loud knocking at idle only 1988/305/TBI
Any ideas?
Any ideas?
Check the torque converter to flexplate bolts , I've seen an instance where those being loose caused a rapping sound only at idle like you describe .... Supreme Member
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Any ideas?
Any ideas?
Engine: 4++,350 & 305 CIs
Also the flexplates like to crack all the way around the crankshaft bolts.
