Recommendation for scanner tool
Old Oct 19, 2020 | 08:46 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
Just wanted a few ideas on a good scanner tool to aid in tuning and repair for my TPI GTA, I know the Snap On “brick” MT2500 is great but weeding through eBay for one has been exhausting. I just don’t need all the extra stuff when I will only use it for my GTA.
Old Oct 19, 2020 | 09:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Recommendation for scanner tool
Just get a aldl cable like moates.net sells and download tunerpro rt
Old Oct 19, 2020 | 09:49 AM
Engine: 5.7 L98
No laptop, if I had one I would do that route. I should of clarified, I don’t plan on doing my own chips just something so I can see air/fuel and pretty much what the sensors are telling the ECM.
Old Oct 19, 2020 | 11:21 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Its worth it to buy a cheap laptop
Old Oct 19, 2020 | 12:35 PM
Twin_Turbo's Avatar
Red brick
Old Oct 20, 2020 | 07:11 PM
Engine: 5.7 L98
That tuner pro rt and the cable would be all in for $120 as long you have a laptop, that’s not a bad deal. May try to dig up my old laptop and give it a shot. Thanks for the suggestions
Also saw some 12 pin cables on eBay for like $55
Old Oct 20, 2020 | 09:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Moates should be around 80 bucks or so but other cables may work. Tuner pro can be downloaded and used for free. Theres a donation option so you dont have to wait 10 seconds before using it each time
Old Oct 21, 2020 | 08:18 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Frank (the Tank), Moates cable and a cheap laptop. Any windows laptop. If you have a friend that has an old one that boots up it will work. Waay better. Plus, the guys that tune need you to collect data logs and you use a laptop.
I've also found it helps to turn off any cellular/bluetooth/wifi signals near the car while you are doing data collection. Mine was very sensitive.
ikeepitreelz
Firebirds Wanted
Jun 2, 2020 07:16 PM
WaOnFiRe
Aug 31, 2004 10:38 PM
