Lt1 vs gen 1 cam
Old Oct 20, 2020 | 10:00 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Lt1 vs gen 1 cam
Looking at cams. The difference between the 2 are one says for lt1 and the other is gen 1.
What is the difference? $100 price difference between them. Same lift/duration/timing specs
Comp cams
8-467-8
​​​​​​7-467-8
Old Oct 20, 2020 | 10:19 PM
Re: Lt1 vs gen 1 cam
LT1 cam doesn't have the fuel pump lobe, for sure. Also has the long dowel pin in the front to work the WP & Opti. May or may not have the distributor gear.
Lobes and that sort of thing are the same.
Old Oct 20, 2020 | 10:22 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Comp cams
8-467-8
​​​​​​7-467-8
An SBC cam won’t work in an LT1/LT4, but an LT1 cam will work in an SBC. The LT1 cam has the dowel pin in front to run the optispark. It can be shortened or removed for an SBC. Also, the LT1 cam may not have a mechanical fuel pump lobe.
Old Oct 21, 2020 | 07:56 AM
Vader's Avatar
The "second" LT1 cam also has the distributor gear teeth, needed to drive the stub shaft in the rear of the lifter valley. That shaft drives the oil pump, but not a conventional SBC distriibutor.
I know that a 1994 factory LT1 cam had the area for the fuel pump machined concentric with the blank (flat) but the Comp Cams replacement cam designed for that LT1 had an eccentric fuel pump lobe.
camaro211z28
Apr 18, 2012 10:44 AM
ponykiller
Sep 26, 2003 01:17 AM
Brian Felts
Oct 28, 2002 07:16 AM
89formula#1
Feb 3, 2002 09:05 PM
fordsuks91
Sep 30, 2001 09:03 AM
