Reddragon88gta
close
- Join DateApr 2017
- LocationNorthern NY
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1988 Trans Am GTA and 1979 Trans Am
- Engine5.7 L98
- Transmission700R4
- Axle/GearsBorg Warner 9 bolt 3.27
- Liked:445 Times in 342 Posts
Did a quick search and did not have much luck on where to find replacement U bolts for the sway bar bracket, I broke a bolt when replacing the seat bar for paint and new greasable bushingS. It does not look like an exhaust style clamp will work.
Discontinued by GM. I guess your best bet to find a used one through this forum in the "wanted" section.
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
Some 4x4 shops can make them. I used muffler clamp U bolts for my 9" rearend. been in there for 20 yrs or so.
Reddragon88gta
close
- Join DateApr 2017
- Engine5.7 L98
- Transmission700R4
I’m going to try my local dealer to see if they have anything that will work, then try O’reillys and see if they have a clamp that will.
T.L.
close
- Join DateSep 1999
- LocationColorado USA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'83 Firebird (T/A Clone)
- Engine350 with L-69 components
- Transmission700R-4, 2000 RPM stall converter
- Axle/Gears10-bolt/3.73 ..
- Liked:822 Times in 630 Posts
Any company that sells U-bolts should have some in the size you need. They're just U-bolts...
midias
close
I got some for exhaust pipe they were a little tight but they worked
gt4373
close
- Join DateNov 2011
- LocationCT
- Car1984 Chevrolet Camaro Z28
- Engine5.0 Liter 4-BBL V8 High Output
- Transmission5-Speed Manual
- Axle/Gears3.73
- Liked:355 Times in 205 Posts
Reddragon88gta
close
- Join DateApr 2017
- Engine5.7 L98
- Transmission700R4
Thanks for the replies, O’Reillys had a 2.5 inch exhaust clamp that worked perfect. I am cleaning up/painting the base that came from the factory to reuse with the new U bolt.
sofakingdom
close
- Join DateSep 2005
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
You could take a piece of allthread and just bend it around the axle tube.
