3.73 series 3 carrier on rear?
Car: 06 Toyota Tundra SR5
I heard my rear is a 10-bolt, 7.5" diameter that is a series 2 carier...will series 3 fit? I heard u ahve to ahve an adapter, is this expensive or a hassel?
Transmission: 4L80E/4L80E
If you are getting gears to fit your current carrier, 3.73 gears are available to fit a 2-series carrier.
If you are getting gears and a carrier, then stick with 3-series for both.
The "adapter" is simply a spacer that goes between a 2-series carrier and a 3-series gear. Works, but generally not recommended if it can be avoided.
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
