has anyone ever air tested a intake manifold
Old Jan 7, 2021 | 06:15 AM
kroot's Avatar
I am having very hard time sealing this intake, on a gen v 7.4L, aluminum intake. the problem started when I noticed coolant in the oil, this is a reman long blk. for a boat, stock engine w/peanut ports, so before I aid the oil and coolant I've been air testing the coolant side and I'm getting bubbles when I soap test it with 20# of air have put sealant on the bolts and around the water ports and I still get bubbles
Old Jan 13, 2021 | 07:40 AM
Vader's Avatar
Re: has anyone ever air tested a intake manifold
Welcome Aboard!
Perform a search for "casting impregnation" and you might get some ideas. If you've covered all the bases with the gasket surfaces and seams, there might not be much left.
0pyders
Mar 11, 2020 11:13 PM
K88-79
Feb 25, 2011 05:28 PM
gvampyr
Mar 9, 2008 12:13 AM
trueburton
Mar 12, 2005 07:12 PM
1MeanZ
Apr 11, 2003 09:12 PM
