Pulling the intake manifold, need some help
Old Mar 11, 2005 | 04:04 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
All right so i have it torn down and ready to pull the intake off. Should i drain any coolant out? I pulled the line off the front and some coolant came out but is there alot in there i am just woorried about it spilling into the engine. Any other suggestions or tips would be much appreciated. thanks in advance
Old Mar 11, 2005 | 06:05 PM
rsn932's Avatar
Yes, you should drain the coolant first. If you don't, it will spill out of the water passages into the lifter valley and go down into the oil pan. Pulling the intake is really easy if you have everything off and out of the way already. Go for it.
Old Mar 12, 2005 | 10:45 AM
SpeeDeamon's Avatar
Car: 1988 TPI 350 and a few add-ons
what type of intake are you putting in there?
Old Mar 12, 2005 | 07:12 PM
trueburton's Avatar
Just replacing gaskets. I has it half torn apart to polish the runners and plenum and port them so i decided to replace teh intake gaskets too since they were leaking a little oil.
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
