Distributor recommendations
Old Feb 19, 2021 | 10:47 AM
BRYDENGTA's Avatar
Car: ProCharged 1988 Trans Am GTA
Engine: 383 stroker with TPiS miniram
Transmission: fully built 700R4
Axle/Gears: late model 4th gen axle
I have a 383 stroker I am currently building to go into my 88 Trans Am GTA. It has the TPiS Mini ram on it and will have a P1SC ProCahrger on it.
I am intending on fitting the Holley Terminator X universal MPFI kit PART# 550-936
I have the MSD 6AL ignition box and MSD Coil
So I am looking for a Distributor to go with this set up. Holley recommend their Duel Sync distributor 565-200 but have not heard anything good about that distributor and
I know the thirgens need the thinner capped distributors so not sure it would fit either.
So can anyone recommend one that they are using on their thirdgens?
Old Feb 19, 2021 | 12:36 PM
GeneralDisorder's Avatar
Re: Distributor recommendations
I'm running the MSD/Holley (built by MSD for Holley) dual sync distributor on my Trans Am with a LINK ECU and it works great. No fitment issues for me. It's a small-cap like the 87+ GM distributor. What bad things have you heard?
That's about the only option if you want full sequential and keep the distributor without going to a crank/cam sensor.
GD
Old Feb 19, 2021 | 12:40 PM
BRYDENGTA's Avatar
GD
i have heard the holley ones pack up after a couple of months. Seen it many times where people say they are rubbish and pack up after a short time.
have you got a link or part number to your one?
Old Feb 22, 2021 | 11:10 AM
BRYDENGTA's Avatar
GD
Is it the MSD Pro-Billet EFI Dual Sync Distributor Part #2375 that you have?
https://www.summitracing.com/parts/msd-2375msd
Old Feb 22, 2021 | 11:57 AM
Basically - I have the black anodized version. Same thing. So are the Holley units. They are all the same and all made by MSD (owned by Holley).
I haven't had any issue with mine. I'm using a LINK three channel igniter and a DUI coil and running my ID1050x injectors as full sequential.
GD
Old Feb 22, 2021 | 12:12 PM
BRYDENGTA's Avatar
GD
thanks for you reply and help. I shall get that one ordered then.
BRYDENGTA
Jan 18, 2021 12:50 PM
IROCUDREW
Feb 7, 2015 09:39 AM
scottsz28
Aftermarket Product Review
22
Jun 27, 2007 10:59 PM
thirdgenrs
Aug 30, 2005 09:57 PM
