Anyone know where this plugs in?
Old Mar 17, 2021 | 07:48 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
I’ve been working on swapping out my intake since 6am and can’t for the life of me remember where the other end of the black connector for the coil plugs in...any description of where to find the connector would be greatly appreciated.
I am thinking it’s on the driver side but I can’t find it...
Old Mar 17, 2021 | 07:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Anyone know where this plugs in?
Icm to coil
Old Mar 17, 2021 | 08:00 PM
Engine: 5.7 L98
Wow, time to stop for the day...in my haze I plugged the IAT plug in the icm, same plug style.
Thanks for saving me from wasting more time. I am taking a rest.
Old Mar 17, 2021 | 08:02 PM
Engine: Lb9
Transmission: M20
Hope it runs great tomorrow
Old Mar 17, 2021 | 08:09 PM
Engine: 5.7 L98
Same here, I am taking my time and had a buddy help most of the day. Tomorrow hopefully I can get the new runners and plenum on and see where it’s at.
Old Mar 18, 2021 | 06:48 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Exactly the same what happened to the mechanic of a good friend. The car sat about one year cause he couldn't find the issue why it didn't start after intake gasket replacement. It took me 5 minutes to find the issue. The coil cable was plugged to the IAT and the IAT was plugged into the ICM.
Old Mar 18, 2021 | 06:58 PM
Engine: 5.7 L98
That makes me feel better, now I hit a roadblock where my plenum seems to be hitting on the fuel rail crossover line. Only reason I can think is because I used 2 washers( equivalent of an extra fuel injector O ring) on each fuel rail post to give the injectors a bit more room to seat which I heard was a somewhat common things with the big mouth intake. Looking like I might need to grind a bit on the bottom of the plenum to make it right, it’s pretty close.
ARAMOS3
Mar 6, 2012 05:42 PM
Dirtbik3r
Jan 2, 2006 02:17 AM
jrod
Apr 2, 2004 07:33 AM
86bird_28v6_5spd_ramair
May 28, 2002 10:05 AM
