‘87 305 carburetor sensor questions
Old Mar 25, 2021 | 04:58 PM
Jake Galla's Avatar
Just got a cam sensor failure code on the OBD reader. I don’t know what it takes to fix the problem or where the sensor is even located.
Any help? Is this a common problem?
Old Mar 25, 2021 | 05:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ‘87 305 carburetor sensor questions
41 EST Electronic Spark Control circuit
......No distributor reference pulses to the ECM at specified engine vacuum.
Old Mar 25, 2021 | 06:42 PM
Your car doesn't have a cam sensor. Those codes don't always mean the same thing; different systems use the same code to mean different things. In these cars, the CC Q-Jets, TBI, & TPI all can have different meanings for the same code. The 6-cyl versions probably do too but I don't know anything at all about them except that some people claim they exist.
There's a list of codes on this site. https://www.thirdgen.org/service-eng...t-error-codes/
I strongly recommend NOT using a "code reader" of that sort, but rather, use the paper clip method.
Old Mar 26, 2021 | 09:59 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
that code will trip if the motor is ever run with the EST wire disconnected, which has to be done to set timing for example.
reset it, see if it stays gone.
Old Mar 26, 2021 | 05:58 PM
GeneralDisorder's Avatar
Also means the timing is locked out so don't drive it - engine damage can occur.
GD
Old Mar 27, 2021 | 08:24 AM
naf's Avatar
naf
it's pretty 'safe' to drive with the EST code set.
even if the EST has failed (like in disconnected) the ignition control module has some rudimentary timing advance built in.
this advance can be observed with a timing light. with EST disconnected (such as when setting timing) bump your rpm's up to 1500 or so and you'll see a jump in timing. it's a step increase.
not ideal for the motor but not inherently dangerous. it's a 'limp home' feature.
Old Mar 27, 2021 | 10:20 AM
The engine in my 84 Jimmy came to me with an Edelbrock carb, a large cap distributor with EST, and no computer (removed). It blew the HG's, hydrolocked, and threw a rod through the side of the block. Likely because it was towing a flatbed with improper timing.
GD
Old Mar 27, 2021 | 06:12 PM
naf's Avatar
naf
or maybe it was the edelbrock carb....
but yes, with the est no longer providing 'proper' timing control you'll eat fuel and likely run hot, especially under load
Old Mar 27, 2021 | 06:13 PM
naf's Avatar
naf
oh and i had an 85 jimmy at one time, with the 2.8
miss that slow work horse
Old Mar 27, 2021 | 07:05 PM
Wow - a 2.8 in a Jimmy? Never knew such a thing existed. I figured the 305 was the small engine. Crazy.
GD
Old Mar 29, 2021 | 08:03 AM
naf's Avatar
naf
it was an S15
forgot they were still making the full size jimmies back then!
Old Mar 29, 2021 | 09:51 AM
Originally Posted by naf
it was an S15
Oh! That makes more sense. Mine is the K5 Jimmy. They actually made them into the early 90's. Well - the K5 anyway. Not sure about the Jimmy specifically but the K5 Blazer for sure.
GD
ericjon262
Nov 5, 2015 08:51 AM
Hlvo13
Apr 18, 2014 06:01 AM
ericjon262
May 9, 2012 11:54 AM
snoopybg
Jul 23, 2011 09:35 AM
ACoffey
Jun 3, 2008 08:50 AM
